dogcmp6
- July 24, 2015
- 2004 Ford Explorer XLS
Hey guys, so I am buying a 2004 Ford Explorer, and I had it in for the inspection through my mechanic this morning. He mentioned that the Front Right ABS sensor needs to be replaced, and the 4x4 system is throwing a few codes as well.
My first question is, if the 4x4 light is flashing codes, will it disable the 4wd system from engaging (The truck does have 4x4 auto)
My other question is, what are the odds that the ABS wheel sensor is causing the 4x4 system to code? also if the 4x4 system is coding, will it disable the 4wd, or does it depend on the code its self?
