2004 XLT Door Panels | Ford Explorer Forums
cas14psu
Fairfax, VA
2004 XLT
How do you get the front door panels off a 2004 XLT?
first: take out two screws/bolts at the very bottom
next: use a small flat head screw driver to pull the piece off that goes behind the door handle.
next: pop off the piece that holds the window and door lock controls off (pull back away from the door first, then up). unhook all of the wires after that.
after that: two more screws/bolts where that one piece stated above covered.
lastly: pull up on the door panel and you should be done
