atlbravesfn3
- February 27, 2020
- 2005 Explorer XLT
Hello all,
My ‘05 Explorer with 180,000 miles on it is my first car and has been a great one so far. I recently graduated from college and don’t have a ton of money to throw around.
I have been hearing the “Explorer death rattle” from the rear passenger side portion of the engine for about a year and my mechanic says it’s coming from the rear timing chain. The rattle is primarily present on cold start and usually decreases/ disappears substantially after a couple minutes.
I have been doing as much research as possible on this issue but I thought I’d reach out and see how you guys think I should proceed from here.
Knowing that the oil has been changed regularly since it was purchased with full synthetic would it make sense to go ahead and try to change the rear Timing chain tensioners? Or would that be a bad idea with the potential to make matters worse as I’ve read has happened in some cases?
Or would it be better to just let it run until the cassettes fail and be glad I got close to 200,000 miles out of it?
Any other ways I can mitigate the chances of the timing chain failing? Such as different oil types/ weights, startup procedures or any other tricks you guys may have?
I literally just finished replacing the starter, all 4 strut assemblies, bushings and end links myself so I would hate to assume the car could fail at any time.
I really appreciate any advice you can give!
Nic
Nic
