2005 Ford Explorer Stalls while driving??? | Ford Explorer Forums
smalls325is
2005 Ford Explorer V8
So, this has happened to me three times while driving. I will be driving between 30-40 mph and the vehicle will stall... Lights, radio, all electrics continue to work. The engine stalls so there is NO powersteering. Then, after I have pulled over, I put the vehicle in PARK and restart, no problem.
Any thoughts as to where to look or start. This is the third time in 2-months. I was thinking the ECU or a bad vaccuum, but wanted to poll the world wide web for suggestions.
Thanks for the help,
Dana
Mine does it 3 or 4 times a year. When it happens it is always the same spot on the same road. I just pop the shifter into neutral and turn the key. So far not enough of a problem to look for.
Did you ever find anything on this? Here I am years and year later having the same issue. Drives fine, will randomly stall going under 40MPH, dash lights come on, power steering halts, and it cranks and starts right up no problem.
