2005 ford explorer won't start | Ford Explorer Forums
Omarsalla
benghazi
explorer 2005 limited
hi dears
When I turn the ignition on, all gauges go down below zero, they actually drop very low, which in itself is strange. The car does not start when I turn the key. The throttle does a sort of buzzing noise. When I measure the voltage in the lines going to the throttle, the one that's supposed to feed 12 V has less voltage - around 4 V . when I feed this line using a probe tool with 12 V, the gauges get back to normal, and the car starts.
Start by checking your battery then cables working toward the ign
