Town
- July 3, 2012
- Ottawa, Ontario, Canada
- 2007 Lincoln Town Car
What is the proper method to check the trans oil level? Engine on, trans in park?
Sorry, but the 6r60 is not that easy to check the trans fluid level. Here is an extract from the 2007 model workshop procedure:
Transmission Fluid Level Check
Special Tool(s)
Vehicle Communication Module (VCM) and Integrated Diagnostic System (IDS) software with appropriate hardware, or equivalent scan tool
Material
Item Specification
MERCON® SP Automatic Transmission Fluid
XT-6-QSP (US); CXT-6-LSP12 (Canada) MERCON® SP
CAUTION: The vehicle should not be driven if the transmission fluid level is low as internal failure could result.
CAUTION: The transmission fluid fill plug is located near the exhaust system. The exhaust will be extremely hot during this procedure.
NOTE: If the vehicle has been operated for an extended period at high highway speeds, in city traffic, during hot weather or while pulling a trailer, the transmission fluid must cool down to obtain an accurate reading.
NOTE: If the transmission starts to slip, shifts slowly or shows signs of transmission fluid leaking, the transmission fluid level should be checked.
NOTE: Do not overfill the transmission. The transmission fluid level must be at the upper level of the crosshatch mark.
NOTE: If the installation of a new transmission fluid cooler, cooler tubes have been carried out the vehicle must be driven to get the transmission fluid to a temperature of 88ºC (190ºF) in order to purge the air from the transmission fluid cooling system.
1. With the engine running, place the transmission selector lever in each gear position and hold approximately 5 seconds. Place the transmission selector lever in PARK.
2. With the engine idling (600-750 rpm) in PARK, position it on a hoist. For additional information, refer to Section 100-02 .
3. Remove the transmission fluid fill plug transmission fluid level indicator assembly, located on the passenger side front portion of the transmission case.
4. Separate the transmission fluid level indicator from the transmission fluid fill plug.
5. Wipe the transmission fluid level indicator clean. Reinstall the transmission fluid level indicator only back into the transmission fluid fill plug hole to check the transmission fluid level.
6. Using the scan tool, verify that the transmission fluid temperature is between 80ºC-85ºC (175ºF-185ºF). Do not overfill the transmission. The transmission fluid level must be at the upper level of the crosshatch mark.
7. NOTE: If the transmission fluid is not at the correct level, follow the steps for Adding Additional Transmission Fluid or Removing Transmission Fluid. For additional information, refer to Transmission Fluid Drain and Refill in this section.
Install the transmission fluid fill plug.
• Tighten to 35 Nm (26 lb-ft).
