hunterdan
- October 21, 2004
- Fairless Hills, Pa
- 2010 Chevy Silverado
If you can tell us your gear ratio, it can probably be computed. The speed limiter is probably set around 110 or so. If you know the gear ratio, transmission gear ratios, tire size, and the speed, you can figure out the RPMs. Depending on gear ratios, 3.55 or 3.73, and according to this calculator at 110 mph you will be pulling between 3300-3500 rpms.
http://www.tyres1.com/calculators.html
Dan
Dan
