Hotwire
- September 11, 2010
- Raleigh, NC
- 2006 Mercury Mountaineer
I am about to take my Mountaineer in for service at my local dealer. I have been hearing a ticking noise (posted video in another thread) coming from both valve covers. The vehicle currently has 84,000 miles on it. Is there anything else I should have them check while the vehicle is in for service?
I have had the problem with the water leak at the overhead console from the sunroof. However, it only happened when it's parked front pointing up hill during rain. It doesn't happen when the front is parked pointing down hill. That tells me it must be the drains that are near the back of the sunroof, if there are any.
Other than that, I have had no problems so far. Of course the power running boards do not work. One side does a little bit, and the other is completely locked up and I cannot get the motor/shaft to budge.
I'm not sure how the vehicle was maintained before I purchased it at 83,000 miles, so that may play a part in deciding what you recommend me have the dealer check.
Thanks!
Thanks!
