Traci Block
- December 23, 2016
- Forney, TX
- 2006 Mercury Mountaineer
There is a light brownish-red fluid under the front of my car near where a radiator would leak. I too have had the radiator replaced multiple times (thanks to a lifetime warranty) but I know this is not antifreeze this time. When looking under the car, it appears to look most wet at the two hoses on the bottom of the radiator, but the ground only has one wet spot on the ground. Are these hoses easily replaceable by someone with car knowledge, or is this something that would require a mechanic to do? Also are these compression fittings or do they go in with o-rings?
