2007 Explorer XLT again in trouble | Ford Explorer Forums
MunawarKhalid
2007 Explorer XLT
Dear gentlemen and ladies on this group,
My 2007 Explorer XLT is in trouble once again.
It was perfect; and then it suddenly stopped on the road after a U-turn.
In fact the engine was immobilized or went into a forced shutdown state. I
disconnected and then reconnected the battery (the battery is brand new)
and it did not seem the battery related issue at all. After reconnecting
the battery, the engine started again but shutdown within a few seconds.
The symptoms are random like:
- With just switch ON (for about a minute or so of hard reset), everything
seems normal, just a few DTC's can be read. Then suddenly Coolant
Temperature and Vehicle Skid lights turn ON (Battery and Service Engine
lamps may also blink) and communication stops; Anti-theft light does
not turn ON. Turning OFF the switch and then ON does the same thing
again but now Coolant Temperature and Vehicle Skid lights turn ON
quite quickly.
Before errors appear, the DTC's are:
P1000 OBD Systems Readiness Test Not Complete
U1900 CAN Communication Bus Fault – Receive Error
B1231 Crash Detected
B2984 Deployable Steering Column Circuit Open
B2290 Occupant Classification System Fault, Front Passenger Side
B1318 Battery Voltage Low
After error logs, the DTC's are:
P0600 Serial Communication Link
P2105 Throttle Actuator Control System – Forced Engine Shutdown
P1633 Keep Alive Power Voltage Too Low
An attempt with starting the engine results in either of the following situations:
- Engine does not crank at all, anti-theft lamp blinks, odometer blanks out,
all instrument needles freeze in strange positions, Engine Coolant Temp
and Vehicle Skid icons turn on. Vehicle beeps the same as if I left the
key in the off position with doors open, although the key is in the ON/ACC
position. Furthermore, I can not communicate with the vehicle.
- Engine cranks but does not start; Service Engine light blinks for a while,
and I can read PATS code 1:6.
- Engine starts normally but then shuts down within seconds (random timing)
and again Engine Coolant Temp and Vehicle Skid lights turn ON. The engine
is frozen and if I attempt to start again, it does not but the odometer blanks out.
I have tried various things like:
- Checking all the fuses and relays
- Connectors on the PCM
- Apparent damages on the wiring (I can rule it out as it started happening
while driving)
- Clearing the registered DTC's
- Checking connectors/wiring on the Throttle Position Sensor and Motor
- etc.
Some of the logged DTC's (randomly appear and disappear) are:
B1342 ECU is Faulted
P0604 Internal Control Module Random Access Memory (RAM) Error
P0606 Control Module Processor
P060C Internal Control Module Main Processor Performance
P0607 Control Module Performance
P1260 Theft Detected, Vehicle Immobilized
P2100 Throttle Actuator A Control Motor Circuit / Open
P2104 Throttle Actuator Control System – Forced Idle
P2107 Throttle Actuator Control Module Processor
P2110 Throttle Actuator Control System – Forced Limited RPM
P2111 Throttle Actuator Control System – Stuck Open
U0300 Internal Control Module Software Incompatibility
By the way, I have been getting EGR malfunction codes earlier, but they didn't
appear this time.
Please help me get to a solution of this problem.
Thanks.
Any luck fixing the issue? I have similar problems, codes are not exactly the same but do sometimes show lots of codes, which then narrow down to P060C , P600 and P1674. Though at times there are like 15 or more codes, most matching with what you wrote.
Could be totally irrelevant but when the T case went out in my 97 it would die doing sharp turns/u turns. But it has the control trac posi traction stuff.
