2007 Ford Sport Trac Check Charging System | Ford Explorer Forums
rambo3000
7 days ago my sport trac was having trouble starting and the check charging system came on inside. Battery is only 1 year old but I had it tested and still good, then I took the alternator in and had it test and it pasted. Also clean the terminals on the battery. I then put every thing back together and it stated right up. then two days later the same thing would not turn over and then check charging system light, I unhooked every thing again and then put back but would not start. I let it sit for 5 hours and then it started again and ran for 7 days and then again this morning trouble starting and then check system charging. As long as the truck is running it works fine.
I have checked all the cables and they are clean and nothing out of place
Any help would be great, I just started it again about 6 hours after it would not start.
