rjcamel2355
- February 23, 2015
- 2007 sport trac
I have a 2007 sport Trac 4.0 v6 2wd. I was driving home A few days ago and without warning my truck became doggish no power unless I gave 60% or more throttle. I was doing 65mph. No loud noises or jerking or any other types or signs of breaking. I limped it home it seemed as though there was only one gear it was in.
Took it to the dealer today with a new pcm. They said it isn't the pcm and I should buy a new transmission. I have attached my code scanner code results. The truck goes into park neutral reverse and drive. It will not manually shift into 1,2, or 3 on the console shifter and in drive it seems to be in 3rd gear no power taking off. No broken or burnt wires anywhere I have traced them multiple times.
Possibly a range sensor? Or what do you guys think anything would be helpful I'm at a loss here.
Driving it to the dealer, on my way back my doors auto locked at about 55MPH which I know isn't normal. I'm guessing it is a sensor, or something electrical I checked the fluid, no burnt fluid, full of clean bright red clean smelling fluid. No debris that I noticed, and no broken parts, or anything leaking around the pan or case.
Any ideas, I'll take a shot at anything. I can have it rebuilt for 800-900, but I'd rather not spend it if it's something simple like a sensor.
