2008 Ford Explorer 4.0 running problem | Ford Explorer Forums
Cole2008
2008 Ford Explorer xlt
Hi. I have a 2008 Ford Explorer that just recently started to stall on me while driving. I replaced the fuel rail pressure sensor, fuel pump, fuel pump module, cleaned the maf sensor, throttle body with tps and idle control. When in park it runs great but once you put it in gear the fuel pressure drops 12 pounds but the computer still reads the normal (usual) fuel pressure. I don't have any other ideas on what it can be...please help!
Did you also change your fuel filter? My dad used to own a 52 Willys jeep, it would turn over and idle but as soon as you hit the accelerator it would stall. The filter was plugged like you wouldn't believe.
