vipersinu2
- March 10, 2008
- The Big City of Orange City, Florida
- 2019 Navigator 450hp
zerodevil,
you will need to take the 3 phillips screws on the back side of the motor out, and pull off the cap to spin the shaft, so you can get the notch lined up in the open position so you can get the wedge in place,
after you have the new motor in place and the wedge in. take the board over and plug it in, open the door, see if the motor is turing in the right direction. if you open the door and the board closes, you know the ploiartiy is off, because it is running backwards, remember the left motor is for the right board, and the right motor is for the left board. they may run backwards
take the 3 phillips screws and spin the cap in any direction, that will cause the motor to run in reverse.
