js11801
- June 19, 2024
- Levittown, NY
- 2010 Explorer 4WD Eddie B
I am replacing the front timing chains with the engine still in the vehicle, in my driveway. The upper front cassette broke.
The tear down went well, and I am about to order parts including the timing kit, and gaskets: valve covers, lower oil pan, intake manifold and timing chain cover.
All the other gaskets are easy, but the gasket between the upper oil pan and the bottom of the timing chain cover (and engine block) is not.
I would have to drop the upper oil pan, which seems near impossible in the vehicle.
What's the consensus on just leaving the upper oil pan gasket in place as it looks fine?
Yes, the right thing to do is to change it, but that seems beyond my skill. Can I get away not? It is a metal gasket so I suspect permitex is not a solution.
Thanks in advance.
John
Thanks in advance.
John
