HeatherJohns
- February 27, 2019
- Ocala, fl
- 2010 mountaineer 4.0
Truck went into forced idle the other day. Read the codes and got 2104 and 2112 which were both throttle actuator control center. Cleaned out the throttle body and it ran fine for an hour and did it again. Changed the throttle body motor, nothing. Changed the throttle position sensor, nothing. Then my truck threw a theft code so i had to get new keys made. Changed my actual throttle body with one from a junkyard, worked for 20 minutes went back into idle. Reset the pcm with the computer and again about 15 minutes. Changed throttle body with brand new non heated one, Let it idle rough for 20 minutes and it leveled out and made it another 15 minutes. Tried to do it again because maybe its trying to relearn the new throttle and it wont stop idling rough. Im at a loss here and so is my mechanic I had to call in. I dont want to jump and say its the pcm because the only codes it throws at me are for the throttle body.
