LT Clark
- October 17, 2016
- Tampa, Fl
- 2011 Explorer limited
Found out when I went in on a different issue to Ford that my BCM is going bad. It still works but I was told it was failing. Only option is to get a used one pulled from another car since they discontinued the BCM for the 2011-13 explorers. Ford doesn't have any and will not put a used one in but said if I do they will try and program it. I've been told, only the 11 works in the 11, 12 in the 12 and 13 in the 13 but the replacement worked in all three and since none are made I'm trying to find and reprogram a used 11. Here's what I've been able to do so far w/FORScan. Pulled the asbuilt data, Checked it against the BCM and saved it. Put in the used BCM, coded the Keys to it. It has the keyless start so it had to be recoded to the Remote box and the BCM in that order. Up load the saved BCM and wrote it to the new one however, Every line including the 726-42on where the vin is good but 726-07-01 will not accept the as built data with an error that it's not configured for it.
Does anyone know what the BCM 726-07-01 line is? My as built should be 0300 38 and on the used box, 0101 37. Will not accept the change. Is this a box configuration that is not accepting it or a hardware one.
Any tips? I took it to Ford, they couldn't do it saying that it's vin locked and wouldn't take the upload. They seem restricted on what they can do or what they're allowed to do. Since they erased the key's and didn't reprogram it to the BCM, I sat there in the parking lot with my computer and did it so I could drive the car home on the old bcm.
