2012 Explorer Low-Beams | Page 2 | Ford Explorer Forums
The oem HID's high beam is terrific. By far the best high beam I've ever used. It almost seems like the projector was designed around the high beams.
It's a bi-xenon, and the low beam performance of bi-xenon's is never as good as a dedicated low beam HID setup.
I still may buy a set of damaged headlights off of ebay in the future to take apart and see if I can retrofit a new projector into it.
How often do we use the high beams? Low beams are more important as I am sure most of us use them 99% of the time. How much does it cost to replace the bi-xenon bulbs?
Changing the bulb won't affect performance. Bulbs are expensive as they are a newer type. I've seen them around $200 a pair.
It's a simple change though, as they can be accessed from inside the engine compartment. Most other cars HID's require a lot more effort to access them.
Hi All
are the OEM HID Kit Bi Xenon?
because i will upgrade my normale Halogen Lamps with HID but I'm not sure shall I order a HID low beam kit or an Bi Xenon HID Kit, what are you thinking about that?
thanks
Cheers
Stoev
Although I'm no expert on the subject, from what I've read, I believe the HID used by Ford is the Bi-Xenon. This means it is a single bulb and in Ford's case, it uses a shade to cover part of the bulb on low beam and the shade is retracted to produce high beam.
Do you currently have only a single halogen bulb that produces hi and lo beams or do you have one bulb for hi and one for lo? If you have just a single bulb, and replace it with an HID low beam kit, what are you going to do for high beam?
Hey Peter
I don't know because i will get the car in 1 week ;-)
so I think I will buy a low beam HID Kit...
the only problem is, I'm from Switzerland :-) aaaand when it's the wrong one i will keep it in the garbage :-))
Stoev
Hey Peter
Stoev
I know the Limited has just the one bulb. I assume the other models also just have a single halogen bulb for hi and lo beam. If that is the case, I think you will lose your high beam if you put in a low beam HID kit.
Hopefully someone else can jump in here and advise.
