2012 Limited with Starting Issues | Ford Explorer Forums
Exp2012
South Jersey
2012 Explorer Limited
I have a 2012 Explorer Limited 80,000 miles with push button start. When it is hot from driving and it sits for between 45 min to 60 min then try to restart it cranks and cranks and cranks and then eventually it will start. Only does it when it is hot and has been sitting for 45-60 min. If it sits for a couple of hours it cranks normal and starts in a couple cranks of engine. Cold starts in morning are fine.
Tech I brought it to replaced the injectors (they were only $40 each). Didn't fix the problem. Any ideas? Fuel Pump? Pressure regulator?
Have you checked to see if you might have a clogged fuel filter, or the maf sensor going bad
...Tech I brought it to replaced the injectors (they were only $40 each). Didn't fix the problem...
I'd like to look into this to see how I can help, Exp2012. Send a PM my way with your full name, best daytime phone number, VIN, mileage, and servicing dealership; I'll get to work. :thumbsup:
Crystal
