2013 Ford Explore Cooling and Blower issue - HELP | Ford Explorer Forums
forumoto
Explorer
Greetings to all members..
Ford Explore
Vin: VIN: 1FM5K8F87DGA01103
Issue,
Blow turn on by itself and when it happens this way, you cannot control it on the panel, it makes all buttons unoperational, and then it will tune the direction to blow heat only all over the car.
Sometimes, the blow wont come on at all, and when you turn on the A/c it wont turn on the blower at all.
My colleague who has the car, has had the blower resister changed but still
Secondly, the a/c clutch relay, the earth that comes to CLOSED the circuit are mostly intermittent according to him.
When you scan the HVAC, most of the time, no fault but when you unhock the batter and reconnect in some certain duration, error will come as U0140 lost comm with BCM or GEM but when clear all is gone, but a/c wont work out, even though gas is filled to it requirement..
my concern for him is one
why does the blower misbehave this way and why the a/c also intermittent, thanks and look forward to read from all..
Is this not covered under the warranty?
