121x
- November 23, 2015
- Ontario
- 2013 Explorer Limited
Hi all,
I have been reviewing the forum for a bit now trying to find a more definitive answer to what I suspect is non factory performance. We have a 2013 Explorer (limited) and at highway speed it produces drive train noise that has the truck sound as though it is in a lower gear then it is - like it is in 5th gear when it is 6th. The engine RPM is at around 2000-2200 at about 65-70mph. This seems reasonable.
From what I have read these are supposed to be quiet vehicles so I cannot expect this be a normal/accepted characteristic. Originally I thought this might be attributed to tire noise, however swapping the factory tires with my winters, the same noise is there.
This sounds almost like it could be the rear differential or transfer case. I am wondering if anyone can provide some insight into this issue as described or if anyone has any ideas.
Thanks all.
Thanks all.
