2013 xlt ac questions | Ford Explorer Forums
sickamoose
cape coral
2013 ford explorer xlt
I have a 2013 explorer xlt the ac clutch engages for 5-10 seconds then shuts off and won't turn back on unless I shut the ac off and turn it back on and rinse and repeat. Compressor,pulley,pressure switch, wiring harness, front blower motor, resistor and harness have all been replaced lines have been vacuumed and refilled at a loss here
How was refrigerant charge added if compressor will not stay running?
We were doing it every time it would run for the x seconds it would run. Then having to stop and repeat process
And the low and high side gauge readings when it cuts out?
A manifold gauge high and low reading
Then it will need a scan tool to help identify the problem if not a faulty relay. Sorry
I've swapped around relays and still same thing yeah I'm about to throw in the towel lol
