A little more info would be helpful in trying to diagnose the issue.
After it unlatches can you manually open it and will it remain open? Once open, are you able to close it using the dash button, fob or the button on the 'gate'? You didn't mention which procedure you used to try and open it.
It is possible that the liftgate motor need to be replaced if you don't have a fuse issue.
