tan56
- March 16, 2025
- Oak Grove, MN
- 2015 Ford explorer Limit
I've got a 2015 Explorer Limited with 195k.
I'm getting a vibration/humming noise that comes in around 35ish mph and gets louder as I accelerate. The noise is constant whether I'm on the throttle or not. It doesn't change when swaying side to side. It also seems to be a little stronger on the passenger side.
I've changed the drive shaft, PTU, pass side wheel bearing, and the inner & outter tie rods.. I'm thinking about changing the passenger side axel shaft because it has that small hanger bearing on it. However, the noise seems stronger than that little bearing..
Any advice will be greatly appreciated!
Thank you!
Thank you!
