2016 Explorer Airbag light/Fuel Control Module | Ford Explorer Forums
Captainkbt
Conroe Texas
2016 Ford Explorer
My mother took her 2016 Ford Explorer to Ron Carter Ford near Pearland Tx. because the airbag light came on the dash. Tech called her back saying the “Fuel Control Module” was bad and was going to cost “$800-1000” to fix. What on earth does the airbag and/or airbag light have to do with the “fuel control module”?! Am I missing something here? Thanks in advance….
I had the very same issue and it turned out to be a wiring harness. Ford issued a TSB regarding this issue ( TSB-16-001). It seems the wiring harness under the second row seats becomes "strained". The easiest solution is to release the strain on the wiring harness by popping the harness clip off of the seat frame and hand straightening it.
See the following Youtube video:
Thank you for your response!
