255/70R15's instead of my stock 235/75R15's Anyone done this? | Ford Explorer Forums
SHOBrad
New Milford, CT
1997 Mountaineer V8 AWD
I'm needing new tires for me 1997 Mountaineer AWD with the stock 15's (15x7 I think). Stock size is 235/75 and I was thinking for going with a 255/70. Any experiences? Rubbing? Ride differences? Looking at the Continental CrossContact LX. I got a buddy who works for Continental Tire corporate that can get 'em for me cheap.
Thanks in advance!
Brad
For rubbing and fit:
1) Calculate the overall diameter and width of the tire in inches (many calculators online to do this - search Google).
2) Look up the dimensions against the Lift and tire size info for Explorers thread - factoring in any "lift" you may or may not have.
3) If the dimensions of the tire are less than or equal to that from the thread above, then you are safe.
4) BAM!
I've done this numerous times on musclecars. Take the width up one spec and the sidewall down one.
You're looking at 9 1/4" width on what you have and jumping to a 10" width on the 255's. It theoretically keeps the overall diameter of the tire the same. (sorry didn't stop to calculate that for ya, just assumed on the sidewall %). It will go, but your backspacing is the concern. It always works for muscle cars as we wanted to run wide in back and used spacers (common until the '80's, now we just buy wheels that fit). So measure how much space you have, you're running 3/4" over. divide that in half as obviously the outside and inside will have equal amounts of extra when the tire is mounted. so 3/8".
Do you have that much space on the inside? I'm not sure on my ex, never measured, but usually you will on the rear, check the shock's that's where the rub is. Then check the inside front of your tires for the same 3/8" clearance with the steering turned to the left and right. If you have all that then you're cool.
Now. If you don't want tire rub, then you're going to want to either have stiff as heck suspension, take off plastic, roll your fenders, or take corners and bumps slow like a lowrider.
Not to be racist at all but talk to mexicans. They really roll wheels deep with no tire rub. I'm not sure if most of them get their speedo's redone, but here in Kansas it's pretty serious and they love to talk trucks on wide rims.
Thanks in advance!
Brad
Calculated ROLLING DIAMETERS:
235-75-15 28.88 inches
255-70-15 29.05 inches
The difference for driveline speed is negligible (0.6%). The WIDTH difference is 0.79 inches, about 3/4 of an inch. This difference appears in the TREAD WIDTH, not the sidewall "bulge", and as it is the TIRE OUTSIDE DIAMETER which is likely to cause rubbing, you should have no problem at all! (I did it on my '96) imp
Figgerin' out calculated diameters is easy. Anyone cares to hear, please ask! (Note: figgerin'; NOT fingerin'!)
at highway speeds that's 5mph, around here ok but if you already do 5 over adjust. agreed on the treadwidth vs sidewall. your bulge will be less though still there. your treadwidth will be exact on the first number mm converted into inches. on heavy tread off road tires this is usually stronger as the deeper tread. like i said rolling dia should be the same so i didn't bother. treadwidth will change and there's no calc for bulge that i know of.
at highway speeds that's 5mph, around here ok but if you already do 5 over adjust. .......
At what highway speed??
0.6% error means that at:
60 mph true speed, speedometer reads LOW by 0.36 mph, or indicates 59.64 mph--- that's virtually the same thing......
100 mph true speed, speedometer reads 99.4 mph.........
I think you mistook the .6% number to be like, 5%; it's actually 0.006.
I am currently running 255/70's on my 98 4 door. No problems at all and they look great. Looks tuffer with the wider tires.
im running geolander 265 i believe. the geolanders look pretty beefy and give more of an aggressive look. next thing i want is some rugged nice black rims
How are those Geolanders? I've been looking at them, but people all seem to think that their wet weather handling is awful.
