lee2489
- April 16, 2008
- Greenville, SC
- '99 Limited 5.0
I am going to be doing a brake job on the explorer tomorrow. I went to do it two weeks ago assuming it would be an easy job like the ranger. Well, 3 hours later and i still hadn't accomplished anything but get dirty. i did some research and found this thread. http://www.explorerforum.com/forums/showthread.php?t=107949&highlight=front+rotor+99+2wd . I still have some questions though that maybe someone could answer. If i take the rotors off to get turned, do i have to replace the bearing and the seal on the back side? Should i wait until i need new rotors to do this? How do i know if the bearing needs replacing? Also, the inside brake pad is almost to the metal but the outside one is good. Is this normal and should i replace both at the same time? Thanks.
