Robert Craig
- January 25, 2017
- Henderson , Nevada
- 2003 Ford Explorer xls
Question I have a 2003 explore xls witch is currently a 2wd but I do want to convert it to 4wd, I understand the front and rear great ratio has to stay the same witch I'm planning on running 4.10, and from what I've read looks like in order to install the transfercase all I need to do is remove to tail shat on my transmission and the t case should bolt on. Not sure if I need to replace the rear drive shafts or if I can still use mine. For wiring I know the explorer runs a electric shift motor aka window motor. So that won't be an issue I can wire each mode to its own switch. Just wondering if anyone has done such a swap and exactly what all parts I will need. Becides the t case, front drive shaft and the front differential with axles.
