troverman
- February 3, 2005
- New Hampshire
- 1996 Limited 2WD
My '96 Explorer Limited is just rear drive, yet I live in the snowbelt. I also live near a junkyard that has lots of 4x4 Explorers in it. How difficult would it be to make my 2WD into a 4WD?
I'm thinking I would need a transfer case, a shorter rear driveshaft, a front driveshaft, and probably different suspension along with whatever Ford was using for a diff in the front. New hubs, axles, etc. In popping off the trim panel around the radio, I see the wiring clip to the 4x4 switch is in place. Is any wiring / ECU's required or would the new t-case / front axle be plug-and-play? If I could do this cheap enough, I might be willing to do a lot of work and make the conversion.
Anyone done this or have insight?
Thanks in advance
Thanks in advance
