2wd vs. 4wd??? | Ford Explorer Forums
2wd vs. 4wd???
Poohbair
So here is the deal... I am looking for a CHEAP Explorer to use for my next project... it will be getting a 302, a ZF5spd, and 208F tcase, full width D44 and 9", and probably some 36's. So, I have been looking for an Explorer w/ either a blown up engine/tranny/etc... since I won't be using any of it anyways.
I Just found an Explorer w/ a blown head gasket and a 5spd for cheap, however it is 2wd. Is there a difference in the frames between a 2wd and a 4wd? Is doing the full width D44 swap going to be any different on a 2wd vs a 4wd???
Thanks!
I would say it would be fine since your going to be building all your own Xmembers anyway. What year is it by the way?
It is a 91.
I wasn't worried about crossmembers, or anything like that. My biggest concern was frame with and shape. I have never looked underneath a 2wd Explorer so I have no idea what kind of from suspension they have? Steering box setup? etc...
It is a 91.
It has Ibeams and if your worried about the frame box it it will be fine. As for the steering box the 4x4 and 2x4 should be the same.
As cgriffin_5139 the Frames are the same..
they are the same... use a dana 300 case...4.3:1 twinstick or a np205 same deal 4.?:1 and twinstick both cast iron...bullet proof.
The reason I was going to use the 208 is because it will bolt up behind the ZF w/o having to buy any adapters like I would w/ a D300. I am not using a 205 because they have a horrible low range... it isn't 4.? to 1... they are 1.96 to 1 in low range. To get the 4+ to 1 out of a D300 you have to buy the $500 low range kit. The 208 is 1350 fixed yoke, bolts up w/ no adapters to buy, and it has a 2.61 to 1 low range.
what is the low on the stock transfer case?
2.48:1
