mersberg
- June 25, 2006
- Honolulu,Hi
- 00 EB 4WD
I bougth one used and mounted it to my Ex. I upgraded all the cables to 2/0 welding cable. I get 12.5 volts with the ign off. Ign on I get 13.6 volts. When I turn the lights and AC on I get between 13.2 down to 12.5 volts and the idle drops, if I rev the RPMs to 3000, I get about 13.4 volts. I can never get above 14 volts. Is the rectifier bad ? I believe the regulator is good because it charges the battery but just not as much. I could be wrong but I'm not certain. Could I replace the rectifier or even upgrade the diode(s) in the rectifier with better diodes and still maintain the 300 amps? I know RJMInjection sells 200 amp rectifiers that you could swap out with your 3G alternator and make it a 200 amp but I need all 300 amps for my amp setup.
http://rjminjectiontech.com/?p=7
http://fullsizebronco.com/forum/showthread.php?t=114609
