31" tires how bad will this hurt mpg and perf | Ford Explorer Forums
dukes98
owatonna minn
98 xlt
i have a 98 with the 4.0 single ohc. i am putting 31" on and will soon be doing a poor mans lift, tb and shackles. how will the tire affect the mpg and will i loss a ton of power?
it won't be too bad,, i have just a bit smaller size tires than you do, and i get over 22 on the highway . it takes off a bit slower but the truck isn't a rocket to start with , check the door tag to find out what rearend gear you have, that will make the most difference,, there is a listing of the axle codes in here somewhere,,
i also have the same lift as you,,
oh yeah,, edit this to add , i have the 373 axle ratio,
As corkey said the axle ratio will have the biggest effect on how the truck performs with these tires. So take a look at what the ratio in your truck is. The lower the gearing (numerically higher) the better.
Edit:Here's the link to the chart of axle codes.
I just switched to 31" tires and on my 98 ex sport with the SOHC. I could tell i lost a little power but not much. I also have the 4.10 gears as well as a shackle and tt lift on mine. Still seems to accelerate pretty good.
I actually saw an improvement on highway mileage after switching to 31's, it dropped the rpm's by about 400. I didn't really notice a difference in power but I have the V8.
3.73LS here, 5.0L.. Lost a bit of torque, I want it back... on the plus side.. my speedo is right on now.
As for mpg, dunno... never checked it since I've owned the vehicle.. it'll always guzzle gas.
