33's on 15x7 Wheels | Ford Explorer Forums
33's on 15x7 Wheels
Farrell
Kansas City Kansas
91 Explorer Sport
Will 33x12.50 fit on stock 15x7 wheels, and if so how would the tread ware down.
15x7 is a bit narrow, but it will work. They'll probably wear more in the middle of the tire than the shoulders. 15x8 would be better.
Thanks Alec. Have you ever ran into a place that wouldnt put 33x12.50 on 15x7 wheels?
Some won't due to Explorer publicity, but many shops will. You will find one to do it for you.
If you run a little less than normal air pressure in the 33's then they will wear better...like 28 psi.
I run 33 10.5 's on stock wheels and have them at 25.5 psi and they do wear evenly. just make sure to rotate them on a regular basis..like every oil change or 4k miles .
