mudbug0426
- January 21, 2009
- Allen, Tx
- 96 XLT V6 OHV 4x4
i now have a new problem and i cant seem to figure out whats causing it.
for the most part on every start up my exhaust will pop a little, and when at idle in park or when engine is not under load, it idles smooth, then every now and then it will have a small surge, feels like a cylinder misfires i guess. when driving down the alley i can listen to my exhaust and hear it sputter as well as feeling the truck kick a little. it also does this around 30 mph on a flat road at around 12 or 1300rpms in whatever gear its in. the check engine light is not on.
here is a list of what ive replaced recently
new egr valve
upper intake gaskets and the gasket right under the fuel rail
plugs and wires
maf sensor
iac valve
tps sensor along with jame's tps modd http://www.explorerforum.com/forums/showthread.php?s=&threadid=79362
all 3 o2 sensors
most vacuum lines have been replaced, the ones i havent replaced are fine, i checked
new rubber elbow on pcv valve, those tend to dry out, crack and leak
help would be appreciated. if you've had this problem before, throw me some ideas, i wanna get this taken care of asap.
ive been wanting to check my coil and fuel injectors but i dont know what setting to use on my volt meter and what they are suppose to read at normal
new egr valve
plugs and wires
maf sensor
iac valve
all 3 o2 sensors
