Blue_Oval_Ford
- July 11, 2004
- California
- 1997 Explorer Sport 4X4
I have this ongoing sputter that gets worse when I apply a load to the engine only after it is completely warmed up. It also has a rough idle shudder when warming up from 1000 rpm down to 650 rpm sometimes being worse then others. Here is a list of the things I have done so far.
1. cleaned IAC and MAF
2. replaced spark plugs
3. replaced TPS
4. replaced upper intake o-rings
5. did ONP 0012m
6. replaced front O2 sensors
7. seafoam flush
8. replaced fuel filter and checked fuel pump pressure, all OK
I do need to replace the muffler as the sound is much deeper then when I bought it new and will be replacing it as soon as my muffler gets here. On the highway and and at constant speed it runs great with no loss in power just when I give it a lot of gas. Any help would surely be appeciated.
3. replaced TPS
5. did ONP 0012m
7. seafoam flush
