Explorer Power
- February 10, 2009
- The Netherlands
- '99 4.0 V6 SOHC
I had the same dillema. Quite honestly, I wouldnt run true duals. Even though it sounds good, out 4.0 motors hate it. This is why I built myself an off-road Y pipe 2.5" mandrel bent throughout and ran it to a single muffler then a single 2.5" pipe out the rear. I had dual before this (not true, had a dual in/dual out muffler) and low end torque suffered from this. Going back to a single 2.5" out the rear made it better. You can also run a "dummy" pipe and real pipe if you're going for the look? lol. Anyway, how did you delete your rear 02's? I used to have a tune to delete mine, but I got rid of it due to it needing premium and now my check engine sits on. I bought 02 sims but cannot figure out how to install. Im curious how you did it. Let me know
The O2 sensors where already deleted when i bought the truck..
I think they simulated them in some way yes.
yes single pipe works the best for low end torque, did you gain torque over the stock exhaust?
But i would like dual pipes in the back and as much torque as possible (at least more than stock).
I have made some set ups..
tell me what you guys think...
Stock setup:
Setup 1:
Setup 2:
Setup 3:
