4.0 Injectors | Ford Explorer Forums
4.0 Injectors
H munster
94 ex
Is it possible to pull an injector and clean it or are they disposable? # 6 isnt getting gas but i can hear the injector clicking leading me to believe it is plugged
I beleive you can. Or a place with the machine can. I try and find a good used one, has good spray and all. You might try that bg44k fuel cleaner. Or even some cheap off the shelf fuel cleaner and see if that works first
I can personally tell you that with all the time/effort your going to spend to get down to the injector, clean it, piece it all together and possibly have the same problem..it's going to be much worth it to get the new one while you have it tore down.
Mine costs 60.00 each...FYI...while they're not totally expensive...still, totally worth the tear down.
There are fuel injector cleaning services that are very affordable http://www.accurateis.com/ is one.
Good luck! It is well worth having them cleaned.
