4.0 OHV intake manifold options? | Ford Explorer Forums
fmaster7
Jackson, NJ
'92 XLT 4x4
is there ANY kind of intake plenum that fits on the stock lower intake?
Idk if i want one as of now but I will in the future, im just doing this for SH!TS and GIGGLES lol
why limit yourself to aftermarket upper only?? go for a matched set of upper/lower. thats where the most benefit will be seen.
a 3rd party upper with the stocker lower will probably be mostly for looks, as the maximum performance improvement will not be realized.
I've emailed Tom Morana over at http://www.moranav6racing.com/ about having my Upper and lower intakes ported/polished. Here's what he emailed me in return.
It would be best to get a used upper and lower and send them together for porting, Josh. Cost for doing both will be $175 labor and if you want them solvent tanked, bead blasted and coated with 500 degree rated ceramic engine enamel, that's another $50. You said you could clean them up, so the $50 is an option if you choose. I'll be here when you're ready.
Tom
The plastic molded upper is the best stock option.
It can't be ported, but the inner walls are smooth. And it weighs a few lbs less than the aluminum one.
If you are going to have your intake ported, Tom Morana is the THE MAN when it comes to the Ford Pushrod V6.
Ryan
Ryan
so i am limited, to port and polishing a stock upper and lower. wow what a bummer. ill probably do it but i wanted a different look too
Your not going to see that mcuh of a gain. If it were a boosted application you could possibly build an upper box style manifold.
i wish it was boosted, but im leaving the really expensive parts like that for my mustang lol.
