qwklil4
- May 3, 2006
- Joliet, IL
- 2000 XLT
Here is the situation. I've got a 2000 Explorer with the 4.0L OHV "X" vin motor in it. The gf drives it daily. Apparently, the oil filter wasn't tightened up enough by the jiffy lube ####ers and it was leaking oil BAD. She came to me one day and asked if I knew what the ticking noise was. I checked the oil level. Dipstick was bone dry. Drained the oil, installed new filter, added oil. The ticking is still there, but not quite as loud as before.
Buddy of mine said it sounds like it could either be a bad lifter or valve. After I added the fresh oil, I got under the truck and was checking for leaks. The ticking was pretty loud under the truck as well. It sounds more like a nasty lifter tick vs. a rod bearing going out. It also appears to have a blown head gasket or 2. The truck has been eating coolant for a while. As I filled up the radiator this time around, I found where the coolant was going, as the radiator was filled with a **** brown liquid.
The motor has 140k miles on it. The previous owner didn't take care of the truck for ****. We bought it in 06, as an 00 model, and only paid $3k for it, if that tells ya the condition it was in when we got it. And the gf dont take care of it either.
I'm trying to spend as little money as possible on this thing. So.....the trans needs a rebuild, possibly 1 or 2 blown head gaskets, possible bad lifter/valve, or a rod bearing going bad. If this POS was yours, what would you do first, to get the most mileage out of it, via the cheapest possible fix? What's an easier job? Replacing rod bearings? Or pulling the heads, replacing valve/lifter?
Any kind of guidance on the matter would help in getting every last mile out of this thing before it dies. Oh, and we still owe on it, BTW
