LUBRICATION FOR SLUDGE CONTROL ADDED TO FUEL: At every fill-up add 4 ounces of Marvel Ultimate Oil to every 10 gallons of gas or diesel. An average passenger car tank is 15 gallons, so you would add 6 ounces at every fill-up. Regular use can lead to improved fuel economy. ADDED TO ENGINE OIL:Use...
FORD HAS NOT MADE A 4 CYLINDER EXPLORER UNTIL RECENTLY. THAT SAID, THE 2.3 4CYLINDER WOULD FIT, YOUD NEED A DONER TRUCK TO GET ALL THE CONNECTIONS/HOSE/WIRING RIGHT ETC. iT WOULD LIKELY GET THE SAME MILAGE AS THE 6.
YOU MAY FAIR BETTER WITH A V8 SWAP... BEEN DONE THAT ROAD, HIGHWAY ECONOMY WAS ABOUT THE SAME... BUT AROUND TOWN NOT SO MUCH... BUT IT WASNT A STOCK MOTOR.. AND I DIDN'T INTEND TO MAKE IT FUEL EFFICIENT.
iF YOU WANT TO SAVE MONEY ON GAS, AN EXPLORER (ANY SUV) IS NOT THE RIGHT ANSWER.
so i was curious myself with my 4.0 mountaineer. rated at like 14 city 20 highway or something like that. im not sure how accurate the avg on the gauge cluster is but im definitely doing better than that. but again driving habits make a big difference and i usually get better the the rated mpg. i haven't done an actual calculation on my mpg as i currently dont do enough driving to bother. most readouts are usually fairly close leaning more towards the optimistic side. but even 1 or 2 mpg off im still doing better than the rated. hell even my v6 accord gets better mpg than the rating of the 4 cyl.
