Johnny Glenn
- September 2, 2009
- Charleston, SC
- 02-04 Explorers
Thanks for looking in - 02 Limited that will not come out of 4LO. Tried backing up, disconnecting fuses and 4x4 control module - no luck! Read about manually shifting back by removing shifter motor. I moved the pin to (N - Nuetral) is that the correct position?....but how do I move the slot in the shifter motor to match this new position so I can put it back on. I tried using screwdriver etc and it won't move - do I just leave it off?...I plan on leaving it in 2WD permanently by disconnecting control module also. Thanks
