clarks2001
- April 22, 2008
- Ashburn, Virginia
- 2002 Explorer Limited
Well the other day I noticed that when I turn left (in 2 wheel drive) I hear a popping from the front end. When I engage 4Lo and take my foot off the brake to go idle speed, it moves some then a thud happens. I took it to Cottman transmission thinking my transfer case was bad but they told me that my front passenger axle is bad.
When I replaced my wheel bearing/hub on that side, i pushed the axle in some so i could get the bolts holding the hub on the knuckle off, could this cause a problem like the popping and thud noise thats happening? My front differential is an open differential i believe. So how hard would it be to see if the axle is really whats causing it? Also, if I did by chance push the axle too far, would i have to get a new axle or just re-align it?
