4405 Rear output flange | Ford Explorer Forums
KPT
NC
'95 XL 4x4
get_file.php
So I knew this wasn't right putting it together. Thats with getting the flange nut as tight as I could, engine was turning over.
I'm stumped as to why there is not enough room for the flange to slide on the main shaft in the tcase. Speedo doesn't work. The speedo drive gear, upper tone wheel, and rear bearing are held in the rear case half with a snap ring, it wouldn't fit in if something was too large.... Any ideas??
