KPT
- February 5, 2003
- NC
- '95 XL 4x4
Well I've just gotten my 4405 bolted back together.
The rear/main outputshaft will move 1/8" downwards (and only downwards, toward the ground if the tcase was on a vehicle). The bearing was tight when I pressed it in. Will having the flange and nut on and torqued to spec tighten everything up or is the case half bad?
Front output shaft is solid, doesn't move at all.
