alfcapone
- August 28, 2002
- Sweden
- Vw passat estate
I have a no mod -99, and i've got 4wd auto and 4wd high/low, and when you read in the manual you shuldn't drive with 4wd high on dry pavement.
But the LS in the rear has no problem on dry pavement, and i don't have any lockers in front, then the front shuld work like an ordinary diff, right?
And an ordinary diff, dosn't have any problems with dry pavement, because the wheels can turn with different speeds, right?
And then if i'm in 4wd high on dry pavement, the LS can take care of the different speeds of the tyres in the back, and the ordinary diff in the front shuld be able to take care of the dfferent speeds in the front, because it's just an ordinary diff, right?
So, whats with the transfer case, why shuldnt it work do drive with 4wd high on dry pavement, i dont get it
