4wd auto | Ford Explorer Forums
4wd auto
Limited96
Grand Rapids, MI
96 Limited
hi.. i was driving in the rain the other day and noticed that i was sliding alot. i also noticed that my 4wd isnt 4wd high but 4wd auto. does this mean that it isnt always in 4wd until it needs to be? or does it mean soemthing different?'
i ask because it would be nice to be able to use it in situations like yesterday, when your loosing controll due to the conditions, especially on paved roads.
just curious.
thanks.
That is exactly the type of conditions your 4x4 was designed for. You have 4x4 Auto on your '96. You can use it in the rain or snow. When your rear tires start to slip, your front tires will start pulling. It isn't a miracle cure all though so if you drive overly agressive, you can still over drive the system. You can actually use Auto in any conditions. Beginning with the '97 model year, Ford did away with the 2WD mode and made Auto the standard mode. On mine, my choices are 4x4 Auto, 4x4 High and 4x4 Low. Auto is perfectly suited for pavement. Expect to loose about 1-2 MPG when you are in Auto though.
Just a thought... If you were in 4-Auto and it was still slipping and sliding, I'd suggest getting better tires...
