dirtjockey44x
- May 6, 2005
- Ohio
- 1998 XLT 4x4
This is my first post, so please go easy on me if I'm being a little repetitious here about a common / previous topic...
I own a 1998 Ford Explorer XLT, V6. Everything is stock. I use if for about everything that I can - driving to work, hauling ATVs, occasional light Off-Road, etc. After some snow / ice driving about a month ago, I switched it back to 2WD. (switch on the dash). I immediately noticed that the heavy pull from the 4WD didn't go away. I first shrugged it off as being an ice / cold thing keeping it from disengaging. Unfortunately, that's not the case.
It's still locked in 4WD. I have taken the front drive shaft off to save my drivetrain and tires. Is there a quick fix or home fix that I can do?Is there anything I can do to troubleshoot the transfer case issue? I read about a "brown wire mod" in a post that I read searching on this topic. What is it and would it work?
I'm a decent mechanic. If it's a driveway or garage fix, I can pretty much handle it. I don't want to resort to taking to a mechanic who I'd pay to do the same thing that I could do.
Anything that you could recommend would be great. Thanks!
