4X4 help | Ford Explorer Forums
4X4 help
Asilly50NJ
"Patch"
Hillsdale NJ
93 Solid axel Sport
Ok in my 93 sport with auto 4wd it goes in to high fine, but when i push low it dis engauges....I dont get it??? Has this ever happened to any one else?
are you on N while pushing low?
You need to be in neutral with your foot on the brake to engage Low.
yup tried it today,.......still is all funny:(
Then chances are the shift motor is not working properly. You can take it out and try cleaning it yourself. Fairly simple/cheap fix. The instructions can be found on the Singleton Maintenance Site - Dead Link Removed Not uncommon problem, especially w/the older Ex's. That's why it is recommended to put it into Low at least once a month to keep everything lubed...
