4x4 lights flashing | Ford Explorer Forums
4x4 lights flashing
exsport1996
Ohio
96 sport
ok I have serched a bit and not really sure so here it goses I have a 96 sport with a automatic tranny and select trac transfer case it snowed here lastnight put truck in 4x4 light came on every thing was fine about a mile down the road both the 4x4 light and the 4 low light started flashing and pretty sure I had no 4x4 but i'm in town now nice clean roads anybody got any ideas I really need some help thanks in advance
I have the exact same problem. It didn't do it before I unhooked my battery, but now it won't go away. This is the ony problem I have with the truck at the moment and kind of need it considering its dropped almost 3 inches of snow in the last 6 hours.
Common problem. Do a search and you will find the answers you need.
Could be a problem with the t-case shift motor or the 4x4 module.
I dont know much about genII explorers, but I dont think it would throw a code.
ok had some time to check some things out today it dose go into 4x4 and low but it wont stay in i drive down the road a couple miles and the lights start flashing again so i tried to unhook the battery for about a hour but still the same i would think that it the 4x4 module was bad (the one behind the glove box) the 4x4 wouldnt work at all any ideas also i frogot that when stoping right before i come to a complet stop the abs kicks in like it was sliding even on dry roads could this be part of the problem the sensor in the rear axle mabey?
anybody
Run a search for "4wd lights flashing" and search titles only. I'm having a similar issue to yours and there is a TON of informaiton if you run that search.
