4x4 never used so now it doesn't work, HELP !! | Ford Explorer Forums
badgett
Mount Airy , North Carolina
1998 XLT 4.0 SOHC 4x4
I just bought a 98 Explorer a couple of months ago. Did have a 94. Wish I would have kept it. The last owner said he never used the 4x4. He should have gotten a 4x2 then. DUH! My 4x4 HIGH works fine but no LOW. What is wrong with it ?????
Most likely the shift motor is burnt out
do a search on how to clean the shift motor. That'll probably help :)
Just to make sure is the X in nuetrel and the brake pedal depressed.
Thanks for the helpful info. I guess I will start with cleaning the shift motor. Even if that's not the problem, it probably needs cleaning anyway.
This is your third post on the same subject. Cross-posting is a no-no.
See my response in your other post.
